Bronco II Ford Bronco II
Fuel pressure regulator
Old Mar 8, 2005 | 02:55 PM
bizarro's Avatar
bizarro
One question...
How I now if my fuel pressure regulator is working fine???
I have one problem on my bronco 2, when I press the gas the car works at 2500 rpm (example) but when I leave the gas and press the clutch the car go to 2500-2800 rpm for 2 or 3 seconds, later go down to 1000 rpm, it's the same thing every time when I drive my car, What can be the problem?
B2 1989
2.9L
2WD
manual trans.
Old Mar 8, 2005 | 05:53 PM
mrshorty's Avatar
mrshorty
2 parts to checking a fuel pressure regulator
1) Run engine, then pull the vacuum line off of the FPR. If there's gas in said vacuum line, then the FPR is bad.
2) Measure fuel pressure. A properly functioning FPR will maintain 40 +/- 5 psi KOEO, and a few psi lower at idle (with vacuum line hooked up. Vacuum line disconnected, It should maintain the same value as KOEO).
Idle problems like that could easily be a vacuum leak somewhere or other fault. It seems the best place to start with these (in addition to testing fuel pressure) is to pull codes. Only requires a paper clip. See Ken00's tech info post for instructions.
fosgate3
21
Sep 25, 2020 06:50 PM
boothboy
Modular V10 (6.8l)
Aug 1, 2015 05:59 PM
Ranger GT2
Jan 14, 2006 09:13 PM
heavyd86
Sep 20, 2005 07:38 AM
