Reverse Lights don't work????
Old Mar 8, 2005 | 01:43 PM
McNabb's Avatar
McNabb
Just realized my Reverse or Back-up lights aren't working....
Head lights, break lights, running lights, dash lights all work fine.
I checked the fuse box inside th cab, the fuse looks in good condition. Took out one of the reverse light bulbs, it also looks fine.
Can't figure out what is causing the lights not to work?
Any help would be much appreciated. Could it be so simple like I didn't check the other light and they are wired in series?
thanks-
Old Mar 8, 2005 | 01:59 PM
lwcassady's Avatar
lwcassady
I have the same thing in my 86 Ranger - I'm pretty sure it's the neutral safety switch on the transmission. I also happen to be able to start my engine in any gear. I think it's a simple fix - a small ball is stuck in the switch (auto tranny), I've just been too busy & lazy to mess with it. If you test it by starting it in gear, make sure you have your favorite person stand right in front of the truck so you can hear them scream when you lunge forward.
Old Mar 8, 2005 | 03:08 PM
bcjim's Avatar
bcjim
Does your OD lockout work? If not check fuses again, the same fuse controls both things in my truck. I think it was fuse 25 or 27, I really cant remember, but replacing it did fix my reverse lights. Stating what year you have will get you better help here..
Old Mar 8, 2005 | 08:18 PM
McNabb's Avatar
McNabb
It's a 98 Ranger, 4cyl, 4 Speed with overdrive-manual transmition.
I looked at Fuse 27 and it looked fine, no signs of wear?
Old Mar 9, 2005 | 08:03 PM
Ken00's Avatar
Ken00
Do you have a meter and a wiring diagram?
Old Mar 9, 2005 | 10:31 PM
McNabb's Avatar
McNabb
No, no meter or diagram...Just an amatuer hoping to fix the problem as easy as possible without having to take it in for an arm and leg.
Old Mar 10, 2005 | 06:05 PM
Ken00's Avatar
Ken00
To diagnose an electrical problem your going to need a meter to find out were your losing power or if you have a bad switch, can you borrow one. If you can get one I'll email you the diagram and testing information.
