'56 lap belts vs. 3 point
It looks like many of you have chosen to go the 3 point system. Can I ask for a few opinions on this topic as it applies to the '53 to '56's?
Any installation tips would be appreciated.
Thanks, Doug
All production vehicles went to 3-point belts some time ago because the shoulder belt helps prevent eating the dash or steering wheel in a collision. Of course, proper installation is very important.
There are aftermarket brackets for sale for our trucks to anchor the vertical belt between the door jamb and the cab lateral brace under the window. (See Mid fifty, LMC, etc). But it seems most folks prefer to fab their own from 14 gage or thicker sheet metal. Some even provide for multiple anchor holes to adjust the strap tie-down height, which I thought was slick.
The thread below was pretty instructive regarding installation tips and belt choice. You can find other threads on the topic using the "search" tool on the header at the top of the forum page.
https://www.ford-trucks.com/forums/s...int+seat+belts
Thanks Randy Jack!
You have to decide what is enough. Some people won't feel safe without an airbag or multiple airbags. They think the 3 point belt alone is inadequate.
As kids, we rode in the box of the truck. I haven't seen that in many years, and I don't let my kids ride back there.
The insurance people say that drivers average a property damage accident every three years, and most occur within 3 miles of home. No matter how well or how little you drive, it's not YOU that you are protecting yourself against, it's the other guy that will kill you.
That 3pt belt will hold you in place when that rigid column comes to meet you in your seat. Your panel truck has a stock column. Is your life not worth the cost of a modern steering column?
~25 years ago my wife and I were nearly killed when a moving van type truck pulled out of a cross street in front of us while driving @ 55 MPH. My then fiance was driving and I yanked the wheel at the last moment turning us into the truck's tire rather than driving right underneath it. I am VERY safety concious!
One thing is though that the factory marketed the 56 as safer due to the steeing wheel and column design. hmmmm...
1. Lay everything out before you start painting and committing to interior components. Safety is a total package IMO. Handling, braking etc. Ease of use of controls (like the brake pedal) gets overlooked.
2. Seat belt hardware is only as good as what you attach it too. Grade 8 bolt gains you zero when you mount it to a piece of unreinforced floor. Take a good look, there isn't anything solid to mount it to. Mods are needed.
3. Slight offset of steering column and underhood column shaft might lessen it's effectiveness as a chest spear. Don't go crazy mounting your steering column bracket to the dash. This would probably be a good time for the hardware to give up. Hope I never test mine.
4. And never, ever install a bigblock. They're evil. Your truck will be too fast and will be a safety menace to mankind in general.
Where's John?
DON'T put in a racing harness for street use! This advice and warning comes from someone who actually has 5 point harnesses in two street vehicles but never (well ALMOST never, if you catch my drift...) uses them on the street.
First, for good reason there is only one "harness set" that is DOT approved for street use, it is made by Schroth, and is not a true racing harness. The buckle is a standard seatbelt buckle and the shoulder straps have loops that the lap belts pass through before buckling, unlike a harness where the straps lock into the buckle, and it does not have a crotch strap which is critical to keep the buckle from riding up and crushing your diaphram in a crash.
Second, a harness MUST be correctly mounted. The arrangement/location of the mounting points can have serious implications in whether the belts save your life or kill you. One of the factors in the death of Dale Earnhart was that a lap belt failed because of improper mounting location causing unusual stress. The crotch strap for example needs to come thru a hole in properly designed racing seat just in front of the wearer's crotch, not looped over the front of a standard type seat's cushion. The shoulder harness mount must be at a specific height relative to the wearer's shoulder height or it could crush you spine or break your collar bones.
Third, IMHO any upper body restraint other than an OEM type 3 point should not be used without a properly designed and mounted rollbar/cage to keep the roof from collapsing in a rollover. A harness doesn't allow you to move sideways so if the roof collapses you are left to support the vehicle with your head! Even the biggest NFL linebacker's neck and head isn't strong enough to do that!
Forth, it is not safe to drive on the street with a true harness. The straps, if properly tightened, hold your upper body pinned tightly to the seat. It is impossible to turn around to look out the rear window to back up or lean forward to check traffic at an angled intersection for example. You also probably won't be able to reach the dash switches or radio. Loosening the shoulder straps defeat their purpose and is MORE dangerous than no upper body restraint at all. 3 point belts include an inertia reel to allow necessary movement but lock on sudden pressure.
