I have a vibration in the drivetrain somewhere. When I accelerate slowly it sounds exactly like a carrier bearing is bad. I replaced all u-joints and carrier and vibration still there with no change. This is on a 1992 F-250 Extended cab with a 460 automatic transmission
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Thank you for the reply, but I checked the tranny to engine bolts, removed inspection cover for torque converter bolts and there are no metal shavings in bellhousing. Last night I removed tranny pan and changed fluid & filter just for the gee wiz, but everything is looking perfect. Also looked at differential yoke nut and it was tight and no noticable play in yoke bearing.
I'm running out of things to look at. Any help on this would be greatly appreciated. Thanks
