Dead Alternator in Bronco
Old Mar 7, 2005 | 04:48 PM
Ford_Eddie_Bauer's Avatar
Ford_Eddie_Bauer
Does anybody know what amp alternator would be in my 1986 Ford Bronco Eddie Bauer, 302 EFI?
Or if there is away to tell by looking at my old one?
Thanks in Advance
Mike
Old Mar 7, 2005 | 05:40 PM
RyanMiller's Avatar
RyanMiller
Do you have A/C or power windows?
Old Mar 7, 2005 | 07:08 PM
frty7ford's Avatar
frty7ford
It is usually stamped into the case. If i was replacing it I would compare the biggest one to what you have and if the cases are the same size I would use it. More amps sometimes equals a larger case. The larger case will not always bolt up to existing brackets. It used to be 75-110 amps = a larger case.
Old Mar 7, 2005 | 08:23 PM
datchew's Avatar
datchew
have you checked the brushes?
might be able to just replace those and bring it back to life.
Old Mar 7, 2005 | 11:17 PM
mach10533's Avatar
mach10533
In those years the alt. wiring harness would go bad so it wouldnt hurt to inspect them real good while you are working on it. If they are bad, they are inexpensive and can be found at most auto part stores.
