Push Botton 4X4 Ford
Old Mar 7, 2005 | 04:06 PM
Willywat's Avatar
Willywat
I have a 92 F-150 with push botton 4wheel drive. when i push the botton i can hear the relays click and when i'm under it i can hear a very small amount of movement in the actuater. the transfer case doesn't switch in to 4X4. If anyone has any ideas on what could be wrong or how i can check for things that are wrong let me know.
Old Mar 7, 2005 | 05:27 PM
92supercab's Avatar
92supercab
maybe check your motor, the one that moves the gears. I have heard of people taping it with a hammer and getting it to work. You may want to do a search in this forum on this topic. There should be several threads out there. Good luck.
Old Mar 7, 2005 | 08:04 PM
TRaGiK's Avatar
TRaGiK
Likely the motor is bad. We've done a lot of them at the shop I work at, and through Ford, they're about $500 if memory serves me correctly.
Old Mar 7, 2005 | 08:42 PM
Willywat's Avatar
Willywat
I was told that it could be the motor. i was wondering if there are any tests i can do to make sure it is the motor before i go and spend $500?
Old Mar 8, 2005 | 01:20 AM
92supercab's Avatar
92supercab
I have seen post on here regarding testing the motor. I just can't remember where, it may have been mentioned in someones reply to testing thier own motor.
Old Mar 18, 2005 | 11:34 PM
Willywat's Avatar
Willywat
thanks for the help i got it working i just taped it with a hammer and it started working thanks again
Old Mar 18, 2005 | 11:45 PM
Kista20's Avatar
Kista20
give me the floor shift anyday. Thats one of the reasons I bought my truck, it has manual hubs and the manual transfer case. A lot less stuff to go wrong.
