cleaning aluminum wheels
Old Mar 7, 2005 | 03:54 PM
dmacfordshot04's Avatar
dmacfordshot04
anybody out there have any idea how to remove scale,grease&grime from aluminum wheels? i am thinking more of a chemical solution to apply.
Old Mar 7, 2005 | 11:32 PM
Monty06's Avatar
Monty06
wierd but works try some coca cola it works when you clean aluminum wheels
i use it to clean my wheels. coca cola and a scrubber sponge.
Old Mar 8, 2005 | 09:38 AM
Sycostang67's Avatar
Sycostang67
Don't use anything like carb or brake parts cleaner, it will scar the wheels. I use Mothers mag and aluminum polish(which also works on clear plastic). That or try some polishing compound, I have used it to remove old paint from chrome.
Old Mar 14, 2005 | 12:44 AM
jimbob21rc's Avatar
jimbob21rc
if it is polished alluminum don't spay anything on them, use soap and water and a bug scrubber, one of those square ones, then use some polish. if they are not polished wheels then you can use some alluminum brightener it is an acid, if you can find it somewhere, spray it own let it set about 10 minutes then wash with soap and water and rinse. find someone that does car care for a living they can probally get you some, i used to do it when i worked at M&M CUSTOM AUTOMOTIVE installing wheels and accessories and detailing (cleaning) cars, we got it from a local guy his company was SHOWCAR carcare.
Old Mar 17, 2005 | 09:29 AM
dmacfordshot04
thanks a lot .iwill try the brightener for alluminum.
Old Mar 18, 2005 | 01:44 AM
Outlaw08's Avatar
Outlaw08
Oh yeah, Mothers is a god send, I have never seen my alloys shine like after I used Mother's for the first time.
Old Apr 2, 2005 | 03:40 PM
Maxium4x4's Avatar
Maxium4x4
If you have polished aluminum wheels go to your local truck stop or look for Busch aluminum polish. Busch is the best on the market and uses no acid. Buff the wheel till your satisfied, use a soft clean cloth and use dry corn starch to remove any residue left from polishing. Use air to blow off the corn starch and your done. You can also remove residue with windex window cleaner but the results are not as good as the dry method.
Old Apr 10, 2005 | 03:58 PM
Frost13's Avatar
Frost13
i just recently got some horribly stained and corroded aluminum wheels for my truck. used mothers mag and aluminum wheel polish, and they shine nearly like new.
Old Apr 11, 2005 | 10:24 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Blue Majic is some good stuff also.
Old Apr 12, 2005 | 01:07 PM
jimbob21rc's Avatar
jimbob21rc
also neverdull is a good polish it comes in a can, it looks like cotton and another very good polish is excalibur, it also looks like cotton except it is pink.
Old May 5, 2005 | 12:32 AM
afinepoint's Avatar
afinepoint
What are the stock aluminum wheels on a 01 F350? Polished or not. Mine look heavily oxidized. They were badly scratched and nicked by the previous owner.
I tried some never-dull cleaning clothes in a small area of the wheel but it turned that spot black. The resultant smear does not want to come off.
Reg
Old May 5, 2005 | 09:37 AM
jaybird's Avatar
jaybird
When my aluminum dually wheels get salt grim build up and etc I go to family dollar and buy a gallon of clear white ammonia and a pack of soft fine wool pads.I pour the ammonia on the surface and then scrub with wool and they are clean and bright really quick with no hard labor.Be sure to use rubber gloves and rinse them too.
Old Jul 4, 2005 | 10:59 AM
getnbz's Avatar
getnbz
try this stuff its called magic mix thet have a 2 step system a mild acid the cleans ans polish works great on fuel tankshttp://www.berrydistribution.com/cgi-local/shop.pl/SID=1066500239.25712/page=MagicMix-A.htm
Old Jul 4, 2005 | 08:21 PM
afinepoint's Avatar
afinepoint
I just picked up my seventies aluminum mag wheels from my mom's house. They have been under her house for 2 1/2 decades and are heavily oxidized. Should I use any different chemical or technique on them?
Reg
Old Jul 4, 2005 | 08:35 PM
getnbz's Avatar
getnbz
i would go with a two step technique acid and polish if they are old wheels as you say they wont be clearcoated . and to answer your question most of your manufacturers of metal care products use a wheel like you describe badly oxidized. once you use the acid once or twice then just keep them polished.
