More engine code questions...(kinda long)
So, then I did the KOER (key on engine running) test and pulled codes 24, 25, 71, 87 and something else. One is a bad IAC (intake air charge sensor), one is a knock sensor not operating, one is fuel pump relay and then one was that the ECU detected a reset which I assume was when I erased the codes. There was one other code that I can't think of but it was something to do with the EGR position sensor being out of whack. I don't think I have one of those.
1. I don't know if an 85 w/carb has a knock sensor
2. An 85 w/carb w/mech fuel pump shouldn't have a fuel pump relay
3. And I thought that only Fuel Injected engines had the IAC in the intake.
I'm pretty sure I read them correctly because they repeated twice and I don't think the 85's use 3-digit codes. I'm gonna have my wife help me Tuesday night so I can be right in front of the scanner when it's blinking.
I swear it's almost as if I have a 90+ ECU in an 85. But if that was true it wouldn't run right.
I swear I will get this truck to run right one of these days!!!!
