re-reing from the bottom?
Old Mar 7, 2005 | 12:47 PM
camccardell's Avatar
camccardell
Exclamation re-reing from the bottom?
Is it possible, to re-ring the pistons in my 5.8 from the bottom, without removing the heads and accessories, or the transmission?
Takin the pan off, and thought it might be a swell idea to put on new piston rings while I was at it.
Chris
Old Mar 7, 2005 | 01:31 PM
80broncoman's Avatar
80broncoman
I belive you will find that the pistons wont come out that way.
Jim
Old Mar 7, 2005 | 11:38 PM
85e150's Avatar
85e150
289/302 won't come out the bottom, doubt the 5.8 will either.
Besides, you need new valve seals too.
Old Mar 8, 2005 | 10:36 AM
Mike G's Avatar
Mike G
You might be able to get them out through the bottom. Now getting the pistons IN from the bottom will be another issue....
--Mike
Old Mar 9, 2005 | 06:00 AM
racingstudebaker's Avatar
racingstudebaker
Chris
Nope, can't do it Chris. I been there, tried dat. Besides the cylinders having a taper and a bottom ridge, with what you would have to take off the engine and front suspension and go through to pull them out of the bottom, it's easier to ****** the heads off and do it right. And, like somebody else said, I'd hate to see what you'd have to do to get 'em back IN from the bottom!
Sonny
Old Mar 9, 2005 | 10:42 AM
camccardell
allrighty
thanks guys
Chris
