Another code reader questions
I've found a lot of info, but can't find the "short and sweet" version of how to pull codes. I thought there was a simple method to pull these codes.... like "short these pins and count the check engine light flashes" .
This truck has had a sensor or some other problem for a while now. It drives fine, but the check engine and chargine lights are on. ( Actually charging system is working.) The lights will go out when different devices are used.... push in the cigerette lighter and the warning lights go out - same thing if you turn on the headlights and the blower motor.
Thanks
I'll give it a more indepth look.
thx
