Generator Rebuild Parts source??
I am in need of a few sets of Brushes for my Generator "59 F100"
I have found a few varieties of them but not an exact match. They are the usual 2-wire carbons.
Also any links to other parts supplieres for these Vintage Trux would be appreciated as well. I have always used Sacramento Vintage Ford but they do not have what I need this time.
Regards,
Brad
Rob
Thanks for the welcome...Good to hear that your exp. has been posative here.
I did a search earlier for "Generator brushes" and netted nothing...Then tried Generator and I got tired of scrolling through threads that advised an alternator swap/upgrade...haha....I would actually like to go that route some day but now is not the time.
BTW...I did find me a few sets of Brushes at my local NAPA so I am good to go. I figured it would be a no go in a reg. parts store, but evidently not. ALthough the parts counter person was as surprised as I was that they had them...haha
Cheers,
Brad
There are several vendors that have the brushes designed for your generator. Sounds like you already found some that might work so I won't go into the part numbers and vendor availability on those specifically.
As far as a list of vendors that support our older trucks, there are a few around on various member web pages. If you want, try out the list on my Club FTE site - Earl's World Parts Vendors Links. Enjoy and welcome aboard!
I had the same problem with brushes, they changed sizes in 59 I believe. They got smaller and the older more common size just won't fit. I bought nos ones on the second try. You might as well replace the bearings(check ebay, the old bearings 57-58 will fit newer housing) while your at it and at least clean the armature.
Stick around, -4speed
