Knock in engine identified
Old Mar 7, 2005 | 08:34 AM
Trial and Error's Avatar
Trial and Error
I hope this will help someone else. - I had an engine knock which I could only hear at idle. Sometimes it would go away and then it would come back. It gradually got louder and louder. It finally got very loud. I had already been checking on a rebuilt engine. I decided to take it to my local mechanic before I jumped into replacing the engine. He said that he did not think it was a rod or crank knock, that it sounded more like it was gears not meshing in the distributor or the timing chain/gears. It turned out that it had carbon build-up in a cylinder or two and the piston(s) were striking the carbon. He injected some kind of cleaner, (probably like Seafoam) into the intake, blew it out good, and
the knock was gone. He is now my favorite mechanic. A rebuilt engine would have cost me 3K.
Old Mar 7, 2005 | 08:47 AM
Sycostang67's Avatar
Sycostang67
I have heard good things about that seafoam stuff, I am gonna give it a try pretty soon, seems like it can get more stuff going in through your vacumn lines. Glad your engine is okay.
Old Mar 7, 2005 | 11:11 PM
mach10533's Avatar
mach10533
yeah seafoam works great for removing carbon. I usually pour some in the carb and in the pcv line
Old Mar 7, 2005 | 11:14 PM
pfogle's Avatar
pfogle
The poor mans fix is water. Start the motor, open the throttle up, and pour it in in small amounts.
Old Mar 8, 2005 | 08:44 AM
felixr's Avatar
felixr
you'd have to be some serious kind of poor to not be able to afford a 4 dollar can of seafoam or deep creep(which is the seafoam product that you put inside the vacuum lines) and risk achieving hydrolock over time or at the very least, corrosion
Old Mar 8, 2005 | 06:24 PM
mstarr's Avatar
mstarr
Hey, whatever works. And water DOES work, just don't get carried away!
Ford_Eddie_Bauer
Mar 20, 2011 06:29 PM
mjandros
Modular V8 (4.6L, 5.4L)
Aug 26, 2009 08:47 AM
Andy R.
Jul 22, 2008 07:52 AM
bharris702
May 10, 2004 12:27 AM
