Bronco II Ford Bronco II
88 b2 4x4 several problems
Old Mar 6, 2005 | 02:55 PM
aussimis's Avatar
aussimis
i own an 88 b2 4x4 2.9l with 160,000 miles after long trips when i park it and come back after a couple of hours and try to crank it ,it wont start up. it turns over the battery and the terminals are in great condition when trying to crank i cannot hear the intank fuel pump turn on. it never does this after i drive around town only on trips on about two hours long. Also it lags in acceleration on the highway and will stall every now and then with no warning. I have replaced the inline fuel filter. I have no clue in what is causing the problems. Any help would be greatly appreciated.
Old Mar 6, 2005 | 07:00 PM
Monty06's Avatar
Monty06
time to pull some codes and check fuel pressure . normal it's cuased by a faulty electric connection at the fuel sending unit if it's your intank pump.does it crank at all like it wants to start? is your timing set?
cb88
Electrical Systems/Wiring
51
Oct 4, 2019 08:31 PM
airborne0130
Feb 26, 2015 09:07 AM
cb88
Bronco II
Sep 22, 2006 01:59 PM
orion96
Bronco II
Feb 19, 2005 05:42 PM
