Tachometer
Old Aug 4, 2001 | 01:59 PM
reroy's Avatar
reroy
Tachometer
Old Aug 4, 2001 | 09:20 PM
billygot3's Avatar
billygot3
Tachometer
I have a 95 F-150,351w,AEOD,XLT Eddie Bauer.Want to put a factory tach in.Have found a complete instrument cluster.My question:Is the wiring harness the same if it was not equipped with factory tach ? Looks like I can use my speedometer (want to keep mileage correct)and change the other gauges.
Old Aug 5, 2001 | 11:46 AM
lhoatson's Avatar
lhoatson
Tachometer
I can't speak for a '95, but I've just done this with my '89, and the clusters are pin compatible. I was able to trace the ciruits on the my original and replacement cluster to be sure that they lined up using a multimeter that gives an audio signal when there is continuity.
Old Aug 5, 2001 | 11:20 PM
charlez's Avatar
charlez
Tachometer
Yup, it should work fine. Just swap in the new cluster with your old speedo/odo and you'll be fine. I did this on my 93 with no problems.
