Mazda 5 speed problem? Hard shifting.
Old Aug 7, 2001 | 04:34 PM
LynnA's Avatar
LynnA
Just bought an F-150 6, 5 speed Mazda. It shifts hard into second sometimes. About half the time I think. Can be pulled into gear but its hard. Other times no problem. Have changed the fluid. Wondering in it is a sychro that is warn. 160,000 miles.
How difficult to fix?
Thanks, Lynn.
Old Aug 7, 2001 | 07:20 PM
laredo7mm's Avatar
laredo7mm
Check to make sure that there is fluid in the clutch resevoir. It is located next to your brake master cylinder on the driver's side firewall. Unscrew the cap and remove the little rubber dodad and look to see if there is fluid in it. If not add some DOT3 brake fluid to the fill line. Pump the clutch pedal a few times and check the level again. I always have to keep an eye on mine.
If it is full, and it is hard to shift it may be your slave cylinder has gone bad. I replaced mine at about 137,000. If it is a bad syncro(s), I would think that there would be some grinding involved when you try to shift gears.
Hope this helps.
1992 F-150
302 EFI with 185,000+
5 speed Mazda Trans
Old Aug 7, 2001 | 08:35 PM
Mulletwagon's Avatar
Mulletwagon
Went thru same drill on my 88 Bronco. Turned out to be a worn clutch disk - even though there was no chatter.
Old Aug 7, 2001 | 09:20 PM
LynnA's Avatar
LynnA
Thanks for the help. Many years ago a Ranger I had shifted this way and it was a bad slave cyl. Forgot about that. Will check it tommorrow.
Thanks, Lynn.
Old Aug 8, 2001 | 12:23 AM
bad_influence's Avatar
bad_influence
WHALEY
Aug 13, 2010 08:30 AM
gomsu
1983 - 2012 Ranger & B-Series
Sep 16, 2004 05:45 PM
lascpa
Aug 30, 2004 06:24 AM
hl649
Aug 9, 2002 12:25 PM
LynnA
Jan 21, 2002 02:16 PM
