Sponsored by: Real Truck
2005 Owners Beware
Old Mar 5, 2005 | 10:25 PM
nisiar's Avatar
nisiar
2005 Owners Beware
Just got my first dent today in my two week old 250, and it's all ford's fault! Washed the salt off the truck and found a ping in the back fender- an outward ping. WTF?
How did that happen? Well ford removed the rear fender liners to save $35.00, and this left the opportunity for a bit of gravel to ricochet up into the fender and dent the metal out.
Although I had the intentions of re-fitting most of the stuff that ford deleted, I didn't act quickly enough. So, beware, order your fender liners before your truck comes in, and have the dealer install them.
Old Mar 6, 2005 | 12:25 AM
popkorn's Avatar
popkorn
just wait till that gravel road turns to mud it'll run inside the bed from under the rails,thanks Ford for saving a couple of bucks.
Old Mar 6, 2005 | 01:22 AM
tvsjr's Avatar
tvsjr
What all did Ford delete? Does anyone happen to have part numbers for all the right stuff that needs to go back on? I'm an SD n00b - wasn't aware Ford deleted anything like this.
Thanks,
Terry
Old Mar 6, 2005 | 02:16 AM
Wrenchtraveller's Avatar
Wrenchtraveller
I purchased a sheet 0f 1/16 " sheet of ABS plastic and relaced the fender guards myself. I got the idea from another FTE member who completely lined his inner fender wells with this material. A 4'x8' sheet is around 40 bucks at a plastic supply . I had installed Huskey splash guards and used this ABS to fill in the area that the splash guard misses. I am undecided whether I will line the whole inner fender well as I like to be able to hose off my springs and inner fenders after getting mud up there.
Old Mar 6, 2005 | 08:45 AM
Uptown83's Avatar
Uptown83
Ive got about 10k on my 05 already and I really never worried about that. I would like to buy some ABS plastic sheets though and line it. Where do you find something like that? Hobby Stores? Hobby Lobby?
Old Mar 6, 2005 | 10:55 AM
captchas's Avatar
captchas
Guest
was wondering where all the mud came from under the never exposed bed and t cover
wrench if you should find the part numbers please post them.i'll search as i think some one has posted. be good for a update any way
charlie
Old Mar 6, 2005 | 11:06 AM
refuse2's Avatar
refuse2
(2ea) F81Z 9928370 CA Front left and right $25.42 a piece
(2ea) F81Z 9928370 AA Rear Left and right $19.39 a piece
(8ea) 389358 S Plastic push pins (2 per piece) $.58
these were the part numbers I was told but I haven't got around to it yet but I did at least have undercoated.
refuse2
Old Mar 6, 2005 | 11:19 AM
Fredvon4's Avatar
Fredvon4
If your truck does not have the rear wheel well liners, here are the part numbers for them:
(2) F81Z*9928370*CA list 34.52ea
(2) F81Z*9928370*AA list 26.32ea
(4) *389358*S list .79ea
these go in the rear wheel wells from about 2 o'clock to 5 o'clock and 7 o'clock to 11 o'clock so that the mud/snow/spray doesnt get thrown into each end of the fender
Old Mar 6, 2005 | 12:04 PM
Rongold's Avatar
Rongold
Wheel Opening Liners
This applies to 2004 models also--That's when Ford stopped putting them on. Luckily my 2003 has them.
RON
Old Mar 6, 2005 | 01:25 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Are we talking about the covers...from bed down to frame or the ones in front of and behind each wheel.
Old Mar 6, 2005 | 01:37 PM
Rongold's Avatar
Rongold
Rear Fender Liners
They are talking about the curved ones inside the rear wheel wells.
RON
Old Mar 6, 2005 | 03:43 PM
captchas's Avatar
captchas
Guest
thank you fred. i'll order up a set tomorrow. my bed is full of mud and it's under a t-cover
charlie
Old Mar 6, 2005 | 03:44 PM
nisiar's Avatar
nisiar
Thanks,
Terry
Terry,
Search FredVon's posts, he has written extensively about the dissapearing parts on the SD, and what he has done in responce.
Old Mar 6, 2005 | 04:32 PM
Wrenchtraveller
The 04s had these at least mine did but it was an early 04. I had the hood blanket too.
Wrench.
Old Mar 6, 2005 | 04:41 PM
captchas's Avatar
captchas
Guest
hood blanket i do not want the field mice love to make nests under the hood with it. the wheel well . hello ford where is it and why is it missing. don't need any problems like mike has and don't like all the salt mud from the roads being in my bed.
mike they can knock them out with out painting look in the yellow pages as i don't know the ones in your part of new jersey. auto- body repair- paint less
charlie
