EGR Pipe Threads. Clockwise/CounterClock?
Old Mar 5, 2005 | 09:29 PM
MemOrex's Avatar
MemOrex
Ok, I've searched on EGR valve and read that some people have turned counterclockwise to remove them, but some have turned them clockwise?? I've been turning mine counterclock facing it from the front. (righty tighty, lefty loosy).
Any Input? I got a torch to heat it up, but I dont want to be turning it the wrong way.
Old Mar 5, 2005 | 09:37 PM
ccwilms's Avatar
ccwilms
You've got it! A bunch of WD40 on there helps a lot.
Old Mar 5, 2005 | 09:58 PM
MemOrex's Avatar
MemOrex
Ok, so I am turning it the right way.
Old Mar 6, 2005 | 08:14 PM
51frrdtrk's Avatar
51frrdtrk
Yes, Righty tidgty, Lefty loosey
Old Mar 6, 2005 | 08:43 PM
95 F150's Avatar
95 F150
Hmmm , on my truck I have to turn clockwise to remove the nut securing the EGR tube to the EGR valve, in my case it was righty loosey lefty tightey. I've had mine broken loose several times so I know this is right, no pun intended
Old Mar 6, 2005 | 08:49 PM
MemOrex's Avatar
MemOrex
Hmmm... I can see how it can be a clockwise thread. Guess I can try both ways . I'll see what happens tomorrow.
Old Mar 6, 2005 | 08:50 PM
95 F150's Avatar
95 F150
Trust me it's clockwise, good luck
Old Mar 6, 2005 | 08:55 PM
MemOrex's Avatar
MemOrex
Probably will be clockwise....seeing as how it didn't even budge with this method:
-Pb blaster soaking.
-Hooked a pipe wrench on the nut.
-Got 12awg wire and tied one end to the wrench, one end to a pole (....)
-Backed up the truck!!!
Nothing! No turn. Im surprised the tube didn't break off....lol, im crazy for doing that .
Old Mar 7, 2005 | 06:56 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Go look at a new one at a parts store before you break yours.
Old Mar 7, 2005 | 03:23 PM
MemOrex's Avatar
MemOrex
I got it off... It was clockwise. Man, it's so easy when you use a torch! .
Old Mar 7, 2005 | 04:58 PM
qman's Avatar
qman
Is the nut part of the EGR valve or part of the tube?
Old Mar 7, 2005 | 05:44 PM
95 F150's Avatar
95 F150
The nut slides over the EGR tube.
