Help rocker arm torque spec
Old Mar 5, 2005 | 08:55 PM
ranger74's Avatar
ranger74
I'm rebuilding my 74 360 and need a torque spec for the rocker shaft bolts
Old Mar 5, 2005 | 09:49 PM
Putt's Avatar
Putt
40-45 ft. lbs. after they are tightened two turns at a time front to back an the drivers side and rear to front on the passenger side. I have never had a problem just tightening a turn at each bolt back and forth on each side.
Old Mar 5, 2005 | 10:12 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Rocker shaft torque down
Pttt; I have seen motor production shops run down the rocker shaft bolts with a impact gun "one shot till tight" each bolt. The damn things still run, wow but not my motors. 45 degrees before TDC and after TDC to reduce the cam lift on the rockers to torque the shafts down and in small even steps are best.
Carl....=o&o>....
Old Mar 5, 2005 | 10:34 PM
ranger74's Avatar
ranger74
thanks for the info. you guys rock.
Old Mar 7, 2005 | 10:39 AM
rebocardo's Avatar
rebocardo
I use a click wrench to get them close to tight and then a beam wrench for the final adjustment.
This sounds good, I think I will try this next time instead of doing it straight up.
RideDiesel88
May 8, 2014 04:34 PM
johnsjsj
Oct 7, 2013 11:05 PM
fordpride
Jan 10, 2010 06:38 PM
Blurry94
3.8 & 4.2L V6
Apr 1, 2004 07:14 AM
