Charging headaches
Old Mar 15, 2005 | 11:02 PM
Franklin2's Avatar
Franklin2
Make sure it's hooked up like this. The "A" wire should have the system voltage on it. This is the wire that tells the regulator what the system voltage is.
The "S" wire in this system comes from the ignition switch, and tells the regulator to bring the alternator "online" when you turn the key.
The "F" wire sends out a varying voltage to tell the alternator to charge more or less.
From your previous test, it sounds like the alternator is good.
Old Mar 19, 2005 | 10:45 AM
paragod's Avatar
paragod
Well, I finally got it to work. I had to change out the core support, and I realized that the donor truck for it had the voltage regulator bolted to the support. I pulled that one and used it. (I never refuse free parts!) The sytem is now charging at 14. I am going to get the battery tested soon, because it drags on starting, and it shouldn't, especially since I hadve a gear reduction starter on it. Thanks again for all of your help. My next headache will be the heater blower. I'm going to post about it in the cooling section.
Old Mar 19, 2005 | 01:14 PM
ford390gashog's Avatar
ford390gashog
a am having the same problem too but i will go out and try to fix it thanks franklin for the good ideas now not to hijack the thread but i can't get voltage at the s terminal
Old Mar 19, 2005 | 02:23 PM
ford390gashog
ok i tried it and the alt is good so the voltage regulator must be bad
Old Mar 19, 2005 | 07:00 PM
Franklin2's Avatar
Franklin2
Did you get voltage at the "s" terminal of the regulator? This is important. The regulator won't work without it.
Old Mar 19, 2005 | 09:51 PM
ford390gashog
i have voltage it was the regulator it is the original one which was 30 years old the alt put out 71 amps during the test.so thanks for your help
