overdrive
Old Mar 5, 2005 | 12:55 PM
Frank'n'Ford's Avatar
Frank'n'Ford
overdrive
My truck is a 2004 XLT Scab 5.4 in Arizona Beige. The salesman said to leave the overdrive on all the time unless hauling a load. My mechanic says its best to only use it on the highway or it will be hard on my transmission. What do you all do?
Old Mar 5, 2005 | 01:19 PM
garman's Avatar
garman
leave mine on all the time
Old Mar 5, 2005 | 02:27 PM
ATCS2004's Avatar
ATCS2004
Leave it on all the time unless you are traveling the the hills/mountains. Shutting off in hills/mountains will help you save your brakes.
Old Mar 5, 2005 | 03:17 PM
Ruckus's Avatar
Ruckus
Smile
Leave mine on all the time due to never hauling anything.
Old Mar 5, 2005 | 05:38 PM
DonsFx4's Avatar
DonsFx4
Most of my driving is 2-lane hilly county roads, so I disengage OD routinely. Only when I hit the highways (or go over 60 for a good length of time) will I kick in the OD.
Old Mar 5, 2005 | 06:27 PM
kh1977's Avatar
kh1977
Find a mechanic that works on vehicles from this decade. Overdrives have not been that susceptible to wear since mid 90's. In fact you would probably generate excessive wear on your truck from forgetting to hit the o/d button once you got it up to highway speeds.
Old Mar 5, 2005 | 07:03 PM
ckal704's Avatar
ckal704
The quicker I can get into overdrive, the less fuel I burn.
Old Mar 5, 2005 | 08:29 PM
mkoser's Avatar
mkoser
Automatics are just that....automatic.
Don't worry about shifting up/down or engaging or disengaging overdrive unless you have a specific reason to do so.
Having your transmission "hunt" back and forth between gears is not going to hurt it. That is what it is made for.
The higher engine RPM will probably do more damage to your truck than leaving the overdrive on all the time..
MK
Old Mar 5, 2005 | 09:10 PM
WhëëlMå1's Avatar
WhëëlMå1
Bad idea. I would much rather have to replace brake pads than an automatic tranny. Think about why your truck slows down when you have the OD locked out. Yes, engine braking is one. The transmission and other driveline components are forced to endure the torsional forces of forced decelleration. This WILL lead to a shortened transmission life.
Old Mar 5, 2005 | 09:13 PM
WhëëlMå1's Avatar
WhëëlMå1
As for the original question, you can leave the overdrive on all the time, unless you are towing a load. The additional rpms netted by having the OD locked out will provide for a much easier towing experience at highway speeds. If you leave the OD on, while towing a substantial load (or up/down serious grades), you will be working the torque convertor and other tranny components much harder than they need to be.
Old Mar 7, 2005 | 03:56 PM
ATCS2004's Avatar
ATCS2004
Read the owners manual. It tells you to engine brake and even gives you the reason why! I have been doing this for well over 25 years with all my vehicles and have yet to have an engine or transmission problem. If you want to warp your rotors and have to replace brake pads regularly, then by all means leave it in OD and burn those brakes up going downhill.
Old Mar 7, 2005 | 06:15 PM
Golddig's Avatar
Golddig
Hi,
I disengage the overdrive , when I have the truck in 4 high , in the snow or on icy roads , because the vehicle does not require the extra power, at speeds of 50k or lower, the manual says that it is fine to engage and disengage the overdrive when required , that this is fine or good for the tranny too brake away from overdrive when needed.
Old Mar 7, 2005 | 09:25 PM
Ford-man22's Avatar
Ford-man22
I'm not trying to be a smart a#$, but what does ford consider a heavy load. When I pull my 4 wheeler I leave the thing in O.D. . When I pull something I run the same speed as I would with the thing empty. Unless I pull my tractor or something real heavy, an that's only because the truck doesn't stop that heavy weight real fast. I don't realy think that gearing your ride down is to bad unless you go from say fourth to first.
Old Mar 7, 2005 | 11:24 PM
1brannon1's Avatar
1brannon1
i like the way my truck drives with OD off. the response is better, it's gear selection and shift points are better and i don't have that shudder/hesitation deal when it shifts from OD-3 when going up a hill at 35-40 mph. that bothers me, i wonder if there is a fix for that or just a characteristic of the drivetrain these things have?
Old Mar 8, 2005 | 12:26 AM
ChrisAdams's Avatar
ChrisAdams
The only time I kick the OD off is climbing the Cajon pass. Gets a little loggy in 4th, but pulls it nice in 3rd.
It will stay in OD and run fine if I keep it at 75, but the limit there is 70, so...
Chris
