I won't disagree with you on that. But...most (all?) vehicles don't come with a 4-way, just one of the angled jobbies. What you're describing is a leverage situation, and I agree you can apply much more pressure than your body weight that way. I still contend that lifting is the better way to go--straightened arms and lifting the weight with BOTH legs, like a dead lift (the weight-lifting event that reaches the highest weights, other than a squat).
Jason
I can never stress the use of leverage enough. I'm disassembling a '77 460 motor currently, and was beginning to take the heads off the other day. I brought out my dewalt impact gun, and sure enough, after about 5 bolts, it burned itself up. I put my socket wrench on there, pushed on the block with my feet and pulled back as hard as I could to no avail. Brought home a 4' tube of piping that I put over the wrench, put a bit of muscle into it (not NEARLY what I used before) and those suckers worked loose. Carry around a 3-4' piece of piping that you can put over your lug wrench. If it don't come off with a 4' rail on it and you standing on top of that, it ain't comin off
If you weigh 120lbs, that's the max force you can exert downward, without jumping or bouncing. If you only put one foot on the lug wrench and push down with that leg, you will be putting much LESS force than 120lbs on the lug wrench. By pulling upward, you can control the force more readily as you start to feel it give.
Sorry, dude, you need to take a physics refresher...
Jason
And you need a physiology refresher. If all the muscles in the human body contracted at the same time, they can lift a bus. By your logic, if you can't push down with at least the same body weight that you have with one leg, then you can't stand on one leg or walk up stairs. You're not hanging dead weight on it, you're applying a force to it. That's what muscles do.
Ok, stand up, crouch down (bend your knee 90 degrees), then answer me this: how much force are you exerting on the ground?
The answer: same as your body weight. The ground is also exerting the same amount of force back on you. Now stand up straight. As your standing up, you're now exerting more than your body weight on the ground, but as soon as you're fully erect, you are back to exerting your body weight on the ground. Try it with an analog scale under you.
My contention is that if you don't hold the lug wrench with your hand, your body weight is the maximum amount of force you can apply to it without jumping on it.
Let's say this is all done straight downward. If you weigh 150 lbs, and do nothing to hold yourself down to the ground or vehicle (something heavier than you), and do not jump on the lug wrench, the absolute maximum force you can apply to the lug wrench downward is your body weight. Period. If you hold on to the lug wrench, that is a different story, as you are now introducing leverage into the equation.
Stand on one leg. How much weight is your one leg holding up? As much as you weigh. That's with one leg, without stressing.
Guys,I didnt mean to start an arguement.And the correct term for that L-shaped thingy is a Tire Iron,which by the way is the first thing I toss out when I buy a vehicle.In fact,the only thing I use them for is, If I am at home and need to take a tire off of a wheel,two tire irons make great pry tools!A 4way is a wise investment,and if you use it the way I mentioned,your back will thank you when you get older.
