taking out cam shaft
Old Mar 4, 2005 | 02:53 PM
helicon's Avatar
helicon
i'm about to pull my oil pan and replace the rod bearings. its been knocking pretty bad for about a month and i'm scared the shaft is going to need to be pulled. can i do that without pulling the engine?
Old Mar 4, 2005 | 08:33 PM
1979ford's Avatar
1979ford
Are you talking about the camshaft or the crankshaft? I assume your talking about the crankshaft. You can either pull the engine out or the trans out. The crankshaft is connected to the flywheel which is connected to the trans. If its been knocking for a while, might need to be pulled out and checked over. Sounds like its time for a rebuild.
