240 or300?
Old Mar 4, 2005 | 03:48 AM
stewart's Avatar
stewart
240 or300?
1) How does one tell the difference without pulling the pan? My truck is a 65 Ford F-240 4x2.
2) Is there any book out there that talks about the I-6 I have found plenty on V-8's.
Any help in what cuboc inch I have would be appreceiated.
Old Mar 4, 2005 | 11:43 AM
85e150's Avatar
85e150
pull a plug and pull a small dowel or stiff wire down there. Turn the motor over by hand and measure how far the dowel or wire moves. 4" (3.98) = a 300.
My Haynes manual for the van talks about the motors in some detail with torque, wear and factor clearance specs.
Old Mar 4, 2005 | 11:41 PM
Col Flashman's Avatar
Col Flashman
Is the engine original to the Truck?
If so, cheque the VIN & I.D. Plate & that'll tell you after you desifer it.
Cheers
Colonel Flashman
Red '58 Merc. M-100 HP 300 (bored to 312) I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Old Mar 5, 2005 | 03:46 PM
mattri's Avatar
mattri
This is by no means as accurate as measuring the stroke but if it has a 2 groove pulley on the ballancer it's probably a 240, 3 grooves for the 300. Matt.
Old Mar 8, 2005 | 12:22 AM
stewart's Avatar
stewart
I found out
I did look it up by the vin # and found out it is a 300. Thanks for all the input.
Does anyone know of a 6 cylinder book for these old inlines other than the factory?
Brett
Old Mar 9, 2005 | 07:37 PM
Col Flashman
There really isn't one that's better than the one foMoCo puts out.
So far, from my experiences, they either don't give you enough Intele to go w/ or to much useless Intele & you are overloaded w/ it.
Old Mar 10, 2005 | 12:35 AM
mattri's Avatar
mattri
A Haynes manual will have most of the vital info, torque specs, tolerence specs etc. I think they're better than Chiltons but others will disagree. Matt.
Old Mar 10, 2005 | 09:21 AM
oldhalftons's Avatar
oldhalftons
the 2 groove balancer is the easiest way.
