where do i find auto paint int tulsa
hey guys i got these wierd emials, that say there from fte, but thye don lookk legit, have a look at em
Mailer-Daemon@umit.maine.edu
Sorry. Your message could not be delivered to:
bart chandler,University of Maine (The name was not found at the remote
site. Check that the name has been entered correctly
rodshoptrash@therodshop.com
The message you sent to therodshop.com did not reach its desired
location for one or
more of the following reasons.
1. The prefix of the address you are sending to is not valid or was
incorrect.
2. The email you sent has been identified as spam and was automatically
deleted by the system.
3. The message you sent contained a virus or unidentified code and was
automatically deleted by the system.
We are sorry for any inconvenience.
service@ford-trucks.com
Looking forward for a response :P
password -- 13472
Document.zip
.zip file
do yall think these migth be a virus, i dont remeber sendiing these emails out, at all
and the last one wants me to download sumthin
location for one or
incorrect.
password -- 13472
Document.zip
.zip file
hey sw, the external kill switch wiring only has one wire, so would i take this postive wire wire it up to my switch and at the swtich instead of a negative, just ground it to the frame?
and if i get to big wattage of lights, would it cause the motor not to fire properly? like a weak spark, these would be running ligths so they would get brighter the faster the motor turned
btw thanks for the idea it save me some mula
im not exactly sure how its wired up, but that wire is a positive for sure, the kill switch grounds it to the frame to shut it off.....you might take a look at some new karts with lights on them to see how to wire it up......BTW, nice avatar, my wife and i spent about an hour on that logo, i like it, but i like our other one without the flames better.....glad to see someone got good use of it!! you probably noticed, we put my current avatar on it and changed the back ground......
dang im slow at nght , it took me 6 times to get the avatar part of it,
thats what i thought, see i still have the motor that orginally came on it, 6.0 wiht the smaller fuel tank, but its allripped apart, cuz i tried to fix it , but i found out what piston rings are, and i was done, ne ways i jacked the kill switch off of it, and im going to use that as a lgiht switch, it looks like it had a kill switch at one point and time because right under the steering wheel theres a little hole cut out of the support bar,
i might use a sealed toggle switch with a flipp up cover for the ligths and use the kill switch for a external kill switch
wiat wait wiat, what woudl happen when i turned off the lights, would it turf off the motor, or would it be were to shut off the motor i wuld haft to do it at the motor,
it looks like im giong to be getting teh cheapest mig welder, soem tires and soem lights and maybe a new driven pulley
the front tires are goign to be flat, you knwo the dune buggy style like they are now, like th eback tires, flat ont he actuall tread surface, im going to be putting soem little lawmower turf tires ont,
i testted the brakes one my gravel road DUKES OF HAZARD BABY@!!!!
