IAC check???
Old Mar 3, 2005 | 02:57 PM
lilboysdrivebowties's Avatar
lilboysdrivebowties
IAC check???
Not sure where to post this. How can you make sure the IAC is functioning properly or can you? 351W
I have cleaned it but still encountering idle problems...
Old Mar 4, 2005 | 09:23 AM
lilboysdrivebowties
bump...can you help me?
Old Mar 4, 2005 | 01:00 PM
paulfix's Avatar
paulfix
remove motor, make sure spindle moves freely, suck thru one hole and move spindle to open close valve.
Old Mar 4, 2005 | 01:06 PM
wtroger's Avatar
wtroger
Pull the connector while idling it should die if not it is not working or you have a significant vacumm leak.
