C-6 Speedo Gear
C-6 Speedo Gear
<HR style="COLOR: #666666" SIZE=1><!-- / icon and title --><!-- message -->I picked up a 390 and C-6 from a guy that pulled them from a truck he had scrapped. Didn't get the year of the truck 197?
I am trying to find out what year C-6 I have so that I cold get the correct speedo gear assembly/speedo cable for the truck.
The tranny calls for a speedo gear-cable unit (one piece unit)that slides into the housing and is heald on with a retainer screw instead of having the gear assembly threaded onto the housing and having the cable threaded into the assembly.
The tranny has a flanged yolk for the 2 piece drive shaft instead of slip yolk.
The tranny that was in the truck when I got the truck was a 4 wheel drive tranny that was originally set up to drive a divorced transfer case and the tail housing was never set up for a speedo gear so I can't trade out tail shaft housings between the two
Any help would be greatful
--Mike
Thanks for the reply.
I will look for a 1972 speedo cable.
What I meant by not being able to trade out the tail shaft assembly was that the tail shaft assembly from the other tranny wouldn't work because it was never assembled with a speedo gear assembly. The tail housing had a blank where the gear would have went.
Thanks, Ken
Do you know your ratio and tire size?
John
It looks like I need a 17 tooth gear.
I am running 373 gears and 235/85/16 tires(31 inch)
I counted 6 rungs on the gear on the output shaft but I was told by a builder that it is probably 7 turns or teeth as you call it. I can't see the gear but I felt 6 notches on the gear.
I think I found a speedo assembly locally. I will look at it tonight.
I will just need to pick up a gear.
Thanks for all the help,
I knew I would get a better response here than the drive train section.
Thanks,
Ken
