93-94 Ignition Module(s)
Old Mar 3, 2005 | 01:46 PM
radramrod2's Avatar
radramrod2
Is the ignition module on a 93 F150 Scab w/351W (5.8L) and E4OD the same as one off a 94 F150 Reg Cab w/300-6 (4.9L) and E4OD? These are the new style that are mounted on the drivers' side fender, not actually on the distributor. Doing a motor swap, just wondering if they're the same/interchangeable?
-Rad
Old Mar 3, 2005 | 06:52 PM
midlf's Avatar
midlf
What I would do is go to the parts stores website and look up each vehicle and see if the parts numbers are the same. Check with at least two parts sites to make sure.
Old Mar 3, 2005 | 09:10 PM
paulfix's Avatar
paulfix
not the same, wiring looks different in the shop manual
Old Mar 3, 2005 | 09:18 PM
EPNCSU2006's Avatar
EPNCSU2006
The actual TFI module is likely the same...
Old Mar 4, 2005 | 08:48 PM
GST97's Avatar
GST97
If they are not the same, I happen to have one off a 92 5.8L. I'd be willing to part with it cheap.
-Chris
Old Mar 4, 2005 | 10:55 PM
EPNCSU2006's Avatar
EPNCSU2006
Motorcraft lists a DY-533 ignition module for 4.9, 5.0, and 5.8 for both '93 and '94. The TFI is the same...
Old Mar 7, 2005 | 09:52 AM
radramrod2's Avatar
radramrod2
Silly question, what does TFI mean?
Old Mar 7, 2005 | 12:15 PM
DeepRoots's Avatar
DeepRoots
thin film ignition I thought....
Mine died a year or so back, I found one in a 5liter mustang, different numbers but it fit and worked fine
Old Mar 8, 2005 | 07:24 AM
EPNCSU2006's Avatar
EPNCSU2006
Thick Film Integrated
