Overworking a 400?
Old Mar 3, 2005 | 10:39 AM
Woodman79's Avatar
Woodman79
Overworking a 400?
I have a '79 F250 with the 400 & C6 tranny. Will I work the snot out of this combo pulling a gooseneck trailer with 6000-9000 pounds? Thanks.
Old Mar 3, 2005 | 12:05 PM
79_250RangerLariat's Avatar
79_250RangerLariat
4x4 or 2wd? I pull my 25' goose with my 79 250 4x4 400 4brl c6 and don't have many over working issues. Their's only been once that I've "over worked" the engine starting out on a hill with a load. But it was a very steep incline with a stop sign at the top.. pulling out onto a busy main road.... can't do a rolling stop there very well.
Old Mar 3, 2005 | 12:46 PM
MBDiagMan's Avatar
MBDiagMan
I would worry a lot more about the transmission than the engine. When you pull heavy loads with an a/t, you need to change the fluid OFTEN.
I can't remember the exact numbers, but there was a question on the ASE transmission test about excessive heat drastically shortening the life of transmission fluid. If I remember correctly, for every 10 degrees above normal fluid temperature, the fluid change interval should be cut in half.
Without doing the math, this means change it OFTEN. The fluid temp increases radically when towing a heavy load.
Good luck,
Doc
Old Mar 3, 2005 | 02:32 PM
beartracks's Avatar
beartracks
Keep in mind a hot engine will heat up the tranny and vise/versa as they both exchnge heat in the radiator. Ruining one can ruin the other. I'd invest in some serious tranny cooler and a temp gauge for both.
Old Mar 4, 2005 | 07:25 AM
Woodman79's Avatar
Woodman79
Thanks for the feedback. My truck is 4X4, and it already has a tranny cooler & a oil cooler for the transfer case. It had been built up for plowing snow, but I was worried about towing capacity. I don't have a temp gauge for either the transmission or the transfer case, but I like the suggestion.
Old Mar 4, 2005 | 07:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
Put a filter in the cooling line also to extend transmission life.
Wix transmission/PS filter
Wix transmission/PS filter #58964
Ford equivalent filter kit #XC3Z-7B155-AA
Ford filter alone #XC3P-7B155-BA
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Old Mar 4, 2005 | 07:51 AM
Woodman79's Avatar
Woodman79
Thanks for the help, guys... This site is fantastic!
Old Mar 4, 2005 | 09:22 AM
towtruck's Avatar
towtruck
I agree with installing temperature gauges. On a long heavy pull they will let you know right away what is going on rather than waiting for something to show signs of overheating.
Old Mar 4, 2005 | 11:34 AM
beartracks's Avatar
beartracks
You can use an electric temp gauge as for water temp. Put a sensor in the oil drain by using a reducer, put on in the coolant and another in the tranny remote filter mount. Use a three way switch at the gauge to flip between the three fluids. Works like a charm
