Short trips bad?
Old Mar 3, 2005 | 09:59 AM
ericmj's Avatar
ericmj
Short trips bad?
Would frequent short (100 feet) trips, where the engine doesn't warm up, harm the 6.0L turbo/engine?
Old Mar 3, 2005 | 10:10 AM
huntercgr's Avatar
huntercgr
Constant on/off will harm the engine. Short trips followed by longer trips that do get it up to operating temps wouldn't be ideal, but would help. I don't think there's any real data out there that relates to what would happen if, and when, something bad would happen based on so many variables regarding short trips.
kw5413's Avatar
kw5413
100 feet? Can't imagine that would help any cold engine. IMO.
Old Mar 6, 2005 | 08:57 AM
Frobozz's Avatar
Frobozz
100 feet? I would push it...
Your glow plugs stay on for about 2 minutes after turning the key on. Your alternator can't keep up with the draw of the glow plugs. The high compression of a diesel engine means the starter draws a lot of current, which takes some time to recharge via the alt... but you aren't even charging in the first 2 minutes. So even disregarding how mean you are being to the actual engine in doing that, you are going to be running your batteries down pretty quickly.
Duncan
Old Mar 6, 2005 | 10:20 AM
me1mckee's Avatar
me1mckee
How long do you sit after you travel 100 feet? Is it possible to just leave it running while you are stopped?
Old Mar 6, 2005 | 10:49 AM
SBV45's Avatar
SBV45
That type of driving would harm any internal combustion engine. Besides the above noted reasons an internal combustion engine needs to be run long enough to cause the condensation in the crankcase to evaporate. Short trips cause the condensation to collect and contribute to corrosive chemical action in your engine. I would install an automatic idle controller (AIC) and let it high idle between the moves.
Old Mar 6, 2005 | 05:15 PM
me1mckee's Avatar
me1mckee
Be sure to add the switch and NOT buy the controller from Ford. Refer to the tech folder for details on how to add the Idle control.
