New Engine, EEC-IV Codes
Old Aug 27, 2001 | 01:09 AM
lhoatson's Avatar
lhoatson
Hello!
I have an '89 F-150 5.8L. I just replaced the engine, and it seems to be running great - although there is an intermittent roughness, not quite a miss on occasion. Here's what's got me scratching my head... Initially I would get a diagnostic code 41 - PCM didn't see the HEGO sensor. I found a ground I had missed during the installation, connected it. That cleared up the 41, but it was immediately replaced with a code 44 - Thermactor (smog pump) System not working. The pump is new, it blows air when the engine is running, and the diverter and bypass solenoids appear to be working. I had no fault codes prior to the engine swap - the old motor was just wore out. The vehicle does have unknown mileage - 200,000 would be my guess. The harness appears to be intact, some sensors were replaced, as were the fuel injectors and fuel regulator. I generally wouldn't know there was a problem if the computer wasn't tell me so.
Any help greatly appreciated.
Also, any tips on locating a set of manuals (preferrably on CD-ROM) that have the codes, and all of the test algorhythms? Haven't found anything useful locally. I purchased a service manual, took 3 large binders to hold it all, but it completely ignores things of this nature.
Thanks again
Larry
Old Aug 27, 2001 | 07:44 AM
amsnss's Avatar
amsnss
May want to try clearing the computer codes. My 89 F-150 w/302 clears by starting a diagnostic test on comp and pulling the connector out of the tester in the middle of the reading. May or may not work with yours.
Old Aug 27, 2001 | 01:15 PM
Fordtruxrok's Avatar
Fordtruxrok
If that doesn't work disconnect the battery for a couple of minutes reconnect it and go for a ride doing all types of driving. Then pull any codes and repost them.
John
Old Aug 27, 2001 | 01:46 PM
Fordtruxrok
jemini
Sep 17, 2012 11:19 AM
Schwinn240
13
Mar 25, 2010 06:57 PM
bluestreak1979
1983 - 2012 Ranger & B-Series
Aug 21, 2006 08:48 PM
windfreak
Sep 7, 2003 10:28 PM
