Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Generic Trucks
Old Mar 3, 2005 | 04:03 PM
fordborn's Avatar
fordborn
Nobody said they were less capable!! I did say they were not the work horse they used to be but if you followed the post I also said it was because there was a bigger demand. Face the facts the 1/2 ton truck is not the truck of choice for the work loads anymore. Trailers, loads, job demands have all increased. You go to any work site now and you will not find a 1/2 ton used for more then a vehicle to run around in, all the working trucks will be in the 3/4 and above range. The F-150 is still a great truck and has more strength then ever but it still is only a 1/2 ton and that just doesn't cut it in th real working world anymore.
Old Mar 3, 2005 | 04:33 PM
AG4.0's Avatar
AG4.0
Originally Posted by fordborn
The work horse has also changed and in most cases people are asking a truck to do more and more thus the 150 has become less capable to carry the demand of the new work force.
I took that too meant that they are less capable. I agree that 3/4 tons have become the standard for work trucks. It seems 1/2 tons are used more for pulling boats and more recreational use, but are still as capable as ever.
Old Mar 3, 2005 | 04:40 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Capable yes, but their design intent is not to be hauling loads like they used to, even though they are able to, there isn't a 1/2 ton F-150 purely designed for hauling a load...
SD's have taken up that market posistion, but there are people out there that don't want/can't afford a 3/4 ton, but still need to use it as a truck, yes the F-150 may be able to do it in numbers terms, but its not like the older F-150's, they were designed to haul a load...
Old Mar 3, 2005 | 04:46 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
And my point being is that they should make bell housings that will allow you to exchange a 4.6 for a 5.4 to your manual and a simple electical package to plug and play. These modular engines appear to be a tad more complicated to work on as compared to older bolcks that a lot of us grew up with. We could get aftermarket parts, adaptors, etc, whatever it took to do whatever we wanted to do to our half tons. Some of us want a half ton with go power. In a manual, you already have the gearing you need to match any torque range with your needs.
I don't even see aftermarked companies yet making engine adaptor kits for the 4.6-5.4 swap... and someone should get on the ball since Ford isn't willing to offer anything from the factory unless you pay through the nose several times over for a Lightning ...umm, if they ever get back into that again.
Old Mar 3, 2005 | 05:00 PM
osbornk's Avatar
osbornk
I've had 3 or 4 older F100 and F-150 and my 04 F150 4X4 with 5.4 and 3.73 will haul more and tow more than the older ones ever dreamed of. It's stronger and heavier built than many of the 3/4 tons of yesteryear. We used the older ones for heavier use but we also broke them and didn't have the same expectations we have today.
Old Mar 3, 2005 | 11:37 PM
AG4.0's Avatar
AG4.0
I think because they are more expensive and have shinier paint and nicer interiors that people are just more hessitant to use a truck like a truck. With the exception of the absence of a manual tranny with a V-8, how is the F-150 less designed to haul a load. There is still a Work Truck package available that gets you vinyl seats and knocks $1005 off of the price tag.
Old Mar 4, 2005 | 12:07 AM
fordborn's Avatar
fordborn
I agree they are still designed to haul a load and do so very well. It's just a fact though the loads have become bigger and heavier thus the majority of work trucks are 3/4 and up while the 1/2 have become the choice of the sporting group. There is no doubt that these trucks are far better and will most likely do more then their predecessors but the fact remains that as the demand put upon the pickup increased it soon out paced the 1/2 tons abilities.
Old Mar 4, 2005 | 12:28 AM
73Fastbackv10's Avatar
73Fastbackv10
Originally Posted by duramaximizer
without quoting the entire post i don't think the same truck can get motor trend's truck of the year 2 years in a row am i correct on this i know they say they all are in contention but can they be it consecutively?
They can't, I was talking about in 04. The Tacoma won this year.
Old Mar 4, 2005 | 06:49 AM
IB Tim's Avatar
IB Tim
When posting a reply that is directly above …
THERE IS NO NEED TO USE THE QUOTE FUNCTION
Old Mar 4, 2005 | 10:03 AM
Musclecar_Fan's Avatar
Musclecar_Fan
MEGALODON1.
".....and talk (though just that) of a 6 spd manual transmissio with the 5.7 Hemi being available"
This seems to be more than talk now. Take a look at this.
http://www.arifleet.com/production.html
Look under Dodge Ram Pickup. Looks like the 6 spd will be available in the Dakota as well.
Old Mar 4, 2005 | 01:54 PM
73Fastbackv10
Dude, Tim, that quote wasn't even on the same page.
Old Mar 4, 2005 | 02:21 PM
IB Tim's Avatar
IB Tim
Dude go with the flow....the problem is when you have two thousands posts a day and more than 90% do not need to use the quote function....it saves...
This is a general statement....not at you
Keep
89BlackBeauty
Apr 15, 2008 10:45 PM
Iversen-fords
General Automotive Discussion
19
Oct 15, 2007 12:46 AM
Kraut
Jun 4, 2005 12:49 AM
1956f100
Nov 8, 2003 10:49 PM
hotairflyer
Aug 14, 2003 10:57 AM
