For the past 8 months or so the back end of my f-150 has been squeaking. I have pinpointed the noise to be coming from the leaf springs i think, but do not know what i can do to stop the noise. One person i talked to said i need to replace the plastic spacers in between each spring, i have no idea where i would buy them or if anyone makes them
Anyone else had similar problems?? Any help would be apprieciated.
Thanks
my 97 did the same thing. it was the clamps that fit around the leafs. i just fastened 2 hose clamps togather and put them over the clamp and tightened it and havent heard it since.
I think they were about $17 dollars a side. Instalation was farely easy. I took the weight off of the springs by jacking up the truck by the frame and used a pry bar to help seperate them a little. Hardest part was getting the clamps back on that go around the springs.
