Power steering box adjustment
Old Aug 27, 2001 | 11:07 PM
coreychurch's Avatar
coreychurch
Hello,
I have just resealed my sector shaft with the help from this message board before, so my next question is how do I know how tight or loose to adjust the tension of the steering box with the bolt and lock-nut on the top of the sector shaft? Perferably with the steering box not installed as in my van the bolt is almost unaccessable due to it's relative position to the radiator.
Thanks for your help in advanced.
Corey
Old Aug 28, 2001 | 09:54 PM
jakegypsum's Avatar
jakegypsum
[font size="1" color="#FF0000"]LAST EDITED ON 28-Aug-01 AT 10:55 PM (EST)[/font][p]Corey, Does the box need an adjustment? The adjustment on these boxes are very tricky. Many people who have done them have made them worse and wound up replacing the entire box. The box needs to be installed on the truck first.
The Chilton's book has a very extensive manner of steering box adjustment. Very tricky method using a torque wrench on the steering column. Time consuming also. If you really want to take some slop out, the only thing I can suggest is that you do micro adjustments. One small adjustment every day or two. The point is that you need to let every adjustment seat properly so that the steering gears don't bind. It takes time but from what I understand, it works quite well. Making one primary adjustment is almost sure to cause gear bind. Gear bind is worse than a sloppy gear box. At least that's my opinion. Good luck. Jake.
Jakegypsum // Ford fleet, soup to nuts.
Old Aug 28, 2001 | 10:13 PM
smclaren's Avatar
smclaren
