Service engine soon light
Old Mar 2, 2005 | 07:10 PM
Iron Horseman's Avatar
Iron Horseman
I have a 1995 F-150 XLT. It has 103,000 miles and still is in great shape. But recently my service engine light comes on when I'm running at 55 or better. not necessairly under a load, just at upper speeds. I just got the truck last Monday and the tires aren't stock size and the speedometer jumps a little do to this. Could the service engine light be due to the speed sensor caused by the larger tires or something else. Many thanks.
Old Mar 2, 2005 | 08:25 PM
EPNCSU2006's Avatar
EPNCSU2006
Pull the codes to see what is stored in the computer. You pull them yourself by following the directions that can be found on http://fordfuelinjection.com . Post back what code you come up with if you don't know what it means (there's a list of codes on that site as well).
Old Mar 2, 2005 | 09:01 PM
Iron Horseman
Many thanks. I'll check the codes tomorrow and post the results. btw, I have kin folks in the Raleigh Durham area. Thanks again.
