Sponsored by: Kumho
Problem gettin spindles off
Old Mar 1, 2005 | 03:04 PM
1984F15016's Avatar
1984F15016
i am taking apart my front I beam suspention on my 84 f 150 to paint all the parts, and replace the bushings. I have gotten to takeing the spindles off, and i have taken the two nuts of and now i cant get it off. Is there something that i am missing, i hit the top of the spindle, and it didnt budge, and i cant get it to. There is something that looks like it should come off, but i cant move it. I tried to seperate the spindle from the ball joints because they are going to be replaced, and that didnt buge it either. Any help would be appreciated.
Old Mar 1, 2005 | 03:38 PM
SRD4X4's Avatar
SRD4X4
In the top of knuckle (installed from bottom) is the camber/caster adjuster,if you can get it to move then all you have to do is knock the knuckle loose from the bottom balljoint.On the adjuster,87-up is 12 pt. 1 1/2'',think 80-86 is 12 pt. 1 1/8''.They can be tough to get out.
Old Mar 1, 2005 | 05:22 PM
andym's Avatar
andym
Once you loosen the top and bottom nut on the ball joints, you just bang away at it with a hammer until it falls off. Keep one nut on so it doesn't fall on your foot. If you can't get it to come loose, get a bigger hammer. Do NOT use heat, though.
Old Mar 1, 2005 | 07:42 PM
1984F15016's Avatar
1984F15016
thanks for the help, but my brother came home and gave me a hand and i got it off. There was no other nut, but he drove a tie rod seperator in the bottom ball joint, and beat the upper ball joint until it fell off
