Oil Sensor?
Old Sep 6, 2001 | 02:27 AM
FORDPLAY's Avatar
FORDPLAY
Oil Sensor?
Hello,
My oil guage on my 95 F-150 4.9 L 300/6 is stuck on high!
I replaced the oil sensor going into the block with a new one but, it only worked for a second.
Any ideas on where I should look next?
Thanks, Larry
Old Sep 6, 2001 | 04:11 AM
walterdanek's Avatar
walterdanek
Oil Sensor?
Just a thought, did you disconnect the battery first? I'm told that the computer will remember what a sensor tells it, even after replacing. Pulling the ground off the battery resets & wipes the computer info.
Walter
Old Sep 6, 2001 | 08:15 AM
RGAZ's Avatar
RGAZ
Oil Sensor?
Check the gauge next. Pull the sender wire while operational adn report what happens.
If nothing changed, its the gauge.
BTW-The gauge is just an idiot light and not a true gauge unless you have an older truck. (my 88 has the true gauge).
Randy
Old Sep 6, 2001 | 10:14 AM
stevieray's Avatar
stevieray
Oil Sensor?
