speedometer cable
Old Mar 1, 2005 | 11:45 AM
RDON's Avatar
RDON
speedometer cable
My speedometer needle is jumping quite a bit know.It started on just every now and then.
I was checking through the past post for help,And it sounds like it needs lubed.
To do this I have to take the cable out.Am I going to have to remove the Insterment pannel? I hopeing to just pull it out from the bottom.Will this work?
Don
Old Mar 1, 2005 | 12:34 PM
Rancheroracer's Avatar
Rancheroracer
All I've seen you can't pull out from the bottom, they have a shoulder on the top end. Depending on what you're driving, usually you can reach under & disconnect from speedo head. That lets you get to it to inspect & lube.
Old Mar 1, 2005 | 06:41 PM
RDON's Avatar
RDON
That would help if you new what truck I was talking about. Sorry I forgot to mention that
This truck is a 77 F250 with a standard 4 speed
