locker rear--how many spline?
Old Feb 28, 2005 | 10:53 PM
Teancum's Avatar
Teancum
I've got an '89 F-150 W/4.9l & M5OD, 2WD. The axle code is 19. Am I right in assuming the diff. is an 8.8 in.? How do I know whether it is a 28 or 31 spline so as to order the correct locker when I finally decide which one?
Old Mar 1, 2005 | 01:57 AM
justshootme84's Avatar
justshootme84
Correct, it is a Ford 8.8", 3.55 gear ratio, with 31 spline axles.
Old Mar 2, 2005 | 12:34 AM
Teancum's Avatar
Teancum
Crystal ball
JSM,
Thanks! That was easy (for you).
Old Mar 3, 2005 | 10:40 PM
justshootme84
Your welcome, it's the same axle I have in the 88 Bronco. I completely disassembled it to part it out, so holler if you need any help~!
