Loose Dash
Old Feb 28, 2005 | 06:10 PM
wenger15271's Avatar
wenger15271
Loose Dash
I own a 95 f150 xlt standard cab/bed. The passenger side of the dashboard appeares to have come loose. I have taken the glove box out to see if ican see the bolts/screws, but i see nothing.... any help would be appreciated
Thanks
chris
Old Feb 28, 2005 | 06:44 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 28, 2005 | 06:50 PM
RoadRash's Avatar
RoadRash
If you look between the dash and the door, just above the kick panel, you will see where it is broke. Actually if you remove the pass side kick panel you will see the dash mount and where it is broke.
Ford sells a repair kit for this but I am not sure of the part#. Someone else may have it
Old Feb 28, 2005 | 07:32 PM
92lightning's Avatar
92lightning
You can make a bracket out of a angle bracket. I took a 4 inch bracket and twisted one end. Then used the old screw holes. It took under a half hour. Good Luck
Old Feb 28, 2005 | 07:41 PM
couleeman's Avatar
couleeman
The same thing happened to my 92. I just made a bracket and bolted it in. The rest of the truck may fall off but the dash isn't moving now. It is a pretty simple fix and once you take off the plastic cover on the side you will see what it is.
Old Feb 28, 2005 | 09:22 PM
wenger15271
Thank you
I have been looking behind my glove box off and on for years!!!!! It was right where you said it was and i am going to fix it this weekend.
Thanks
Chris
Old Feb 28, 2005 | 11:01 PM
Blurry94's Avatar
Blurry94
I repaired mine with some industrial adhesive about 4 years ago on my GEN 1 L. I've taken many passes down the drag strip and it has held up great with no signs of cracking.
I aligned the dash with a floor jack and some blocks, applied the "glue", and let it cure for 5 hours.
