Exhaust
Old Feb 28, 2005 | 10:55 AM
lawmar's Avatar
lawmar
Exhaust
I have a 76 F250 2x4 that I need to install exhaust on. I have a 302 out of a 1969 vehicle in it. Since this engine was not an option in the F250 in 1976 I cannot juts order an exhaust system for it. My question is this, do the F150 and the F250 2x4 trucks have the same frame cross beam configuration? If they are the same then I can order the exhaust for the F150.
Old Feb 28, 2005 | 11:08 AM
buzzbait65's Avatar
buzzbait65
this will probably get bumped to the exhaust forum, but, why dont you go to an exhaust shop and get it done....dual 2"-2 1/2" pipes with a crossover, straight back into two mufflers will give you a better exhaust than the factory did, and probably cheaper too, and your 250 wont require cats either
Old Feb 28, 2005 | 11:11 AM
73Custom's Avatar
73Custom
I agree. My custom bent dual 2 1/4" aluminized exhaust with glass packs cost $200 installed. And only took the shop about 1 hour...
Marty
