abs light on
Old Feb 28, 2005 | 08:03 AM
waro's Avatar
waro
abs light on
Mine is a 4X4, 97, since a couple of months abs light has been permantly on. I guess is the speed sensor. I have tried to locate it with no luck. Does anyone has a diagram or picture showing the exact speed sensor location?? Any help will be highly appreciated
Old Feb 28, 2005 | 04:02 PM
maa139's Avatar
maa139
If the setup is like my 94, and I'm pretty sure it is, the rear sensor is on the top front of the differential. I think it's a 10 mm bolt holding it in (it's been a while since I cleaned mine). Remove the sensor, wipe it down with a paper towel and put it back in and plug the wire back in. You should be good to go. Also, if you want to test it while it's out, the autozone page has repair info links that have the resistance spec of the sensor listed.
Good luck.
