broken cruise control
Old Feb 27, 2005 | 08:56 PM
wtrski76's Avatar
wtrski76
The cruise on my '97 PSD (E4OD) seems to have mysteriously quit working. I have checked all the fuses and buttons and they are fine. My code scanner comes up blank, so I am stumped. any ideas?
Old Feb 27, 2005 | 09:46 PM
jcab's Avatar
jcab
I had a sensor that was bad on my 96 I had, I think it was located on trans.? Jeff
Old Feb 27, 2005 | 11:05 PM
JohnApple's Avatar
JohnApple
Is the speedometer working correctly? Or is the needle bouncing around?
Old Feb 28, 2005 | 12:27 AM
SkidRowe37's Avatar
SkidRowe37
Not exactlly sure if the Fords use vacuum for their cruise control system. I had a D*d*e that used vacuum. Maybe something as simple as the vacuum line came off the unit.
Old Feb 28, 2005 | 08:08 PM
wtrski76's Avatar
wtrski76
The speedo and all other gauges work just fine - the cruise is the only thing on the truck that doesnt work. Thanks for the vac idea, but I kind of doubt that Ford uses the vacuum in the cruise since the PSD has an electronic accelerator pedal instead of a mechanical linkage (the breaks also work fine, so no vac leak).... will keep looking for problem...
SatisTraction
1997 - 2003 F150
20
Dec 18, 2023 05:37 PM
540milotalon
Jun 29, 2011 08:51 PM
dyoungen
Feb 20, 2011 03:44 PM
TGenolcyC66
Oct 2, 2010 12:55 AM
tempoffroad
Sep 7, 2010 07:07 PM
