Clunk on acceleration.
Old Feb 27, 2005 | 06:09 PM
first time 4x4's Avatar
first time 4x4
If I try to accelerate hard, peel out, I get a very hard clunks like axle wrap but that's not it. The shifters will both move and truck will violently buck. I replace the trans mount, engine mounts and the clutch. Also have new drive shafts. It will only do it on hard pavement were the truck can hook up. On loose or wet surface there is no problem. Also the truck has 6" of suspension lift and 35" tires. Has a healthy 302 and a Mazda 5-speed. truck is 4x4. The problem was there before the lift so I don't think that is the problem.. The new trans mount has significantly reduced the problem but the truck still won't launch hard on pavement without clunking and bucking. Any ideas?
Old Feb 27, 2005 | 06:10 PM
first time 4x4
Forgot to add that it will do it going forward or reverse.
Old Feb 27, 2005 | 06:23 PM
tex94F250's Avatar
tex94F250
Okay, launch hard on pavement with a 302, 5-speed with a 6" lift and 35" tires? Why, first of all. Second, probably your clutch pack in the rear end or if the driveshafts are not set up correctly for the lift, drive shaft. Either way, continue to do it and you'll have broken axles and the third member won't matter much.
Old Feb 27, 2005 | 07:01 PM
mhallock's Avatar
mhallock
Does it have posi-traction?
I'm not much of a mechanic, but I had a similar problem with an 89 4x4 f150 and when the rear end was opened up, it was a mess. New Posi is not cheap.
Old Feb 27, 2005 | 08:41 PM
mobileraptor's Avatar
mobileraptor
check your motor mounts,
Old Feb 27, 2005 | 08:45 PM
mstarr's Avatar
mstarr
Could also be worn body mounts letting the frame flex to much.
