Replacing an Odometer
Old Sep 16, 2001 | 02:46 PM
big blue's Avatar
big blue
I just received a replacement instrument cluster that includes a tachometer. The odometer reads about 95,000 miles but my current truck reads at about 125,000. Can the odometers be switched? If so, how?
1990 Ford F250 ExtCab 4X4, 460FI, 5Spd, 2 1/2 Lift, 35" BigFoot XT's, 4:56 Gears, KN Filter,3" cat back exhaust, SuperChip
Old Sep 17, 2001 | 01:35 PM
ryanstruck's Avatar
ryanstruck
States may differ on the law, but basically, odometers are not to be touched. This will result in much lower resale value because it has to be asumed there are high miles, and it's ilegal to tamper with the odometer. If you still want to replace it, check with your local RMV or maybe even at your local police station, but I doubt they will be as willing to help you out. This is why on a title it will typically say on the back, something to the effect that "to the best of my knowledge the odometer reading is correct", or something like "I believe my odometer has been tampered with/reset".
Ryan
Old Sep 18, 2001 | 10:59 PM
big blue's Avatar
big blue
I am fully aware that there are laws dealing with tampering of odometers that is why I want my original odometer of 125,000 miles installed into the instrument cluster that shows 95,000 miles. I thought I saw a post on how to do this a while back, but I can not find it after doing a search.
Thanks.
Old Sep 19, 2001 | 06:05 AM
82F100SWB's Avatar
82F100SWB
You'll have to swap the whole speedometer assembly, on the 80-86's it's just two bolts on the back of the cluster, and I'd assume it's the same on the newer trucks with cable driven speedometers. Or, you could move the numbers around, but, it ain't exaclty legal.....
Evan MacDonald
82 F100 FlareSide 4wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
NP 205
3.55 Geared ARB'd 9" & Trac-Locked TTB
31x10.50/15 Cooper Discoverer LT's
Old Sep 19, 2001 | 09:12 AM
ryanstruck's Avatar
ryanstruck
ohhh ohhh, I see what you're saying. Sorry for that confusion. You want it to read the same as it did in the other truck. That shouldn't be a problem, but I'd still check with your insurance company or someone who is an expert on that. Makes sense, though, don't see why it would be a prob.
Ryan
Old Sep 22, 2001 | 06:15 PM
bjoern's Avatar
bjoern
Either keep your old odometer/speedometer part (easy to remove form the cluster), or go to your local speedometer shop, they're certified to do these kind of things. That's what I did when I swapped mine (see webpage).
1988 F-150, V8, 5.0L (302ci), 5spd, SuperCab. Shorty headers, K&N fipk, MSD 6a ignition, Accel 300 8.8mm race wires, Accel supercoil, Accel rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Maybe: Dual exhaust.
http://brembs.net/cars/FordPU.html
Old Sep 22, 2001 | 09:05 PM
Franklin2's Avatar
Franklin2
