my 95 f150 has dim daytime running lights,when i turn my lights on they are normal but the high beam indicator does not work.when i turn on or off the truck highbeam indicator and headlights flash.any one have any ideas
your highbeam indicator is fed from the drl module. I would make sure you had voltage on the black/orange and the purple/orange(with key in run). It seems the only thing common with the dim drl problem, and the highbeam indicator problem, is the drl module.
