300 to 460
Old Feb 27, 2005 | 03:46 PM
yaki69's Avatar
yaki69
Question 300 to 460
ive got a I6 300 and am wondering what all i would have to do to drop a 460 into it. i know i would have to change the engine mounts, but is there anything else that i need to know of?
Old Feb 27, 2005 | 06:34 PM
zwinstead's Avatar
zwinstead
Nothing is the same. Bellhousing pattern is diff, engine mounts and towers are diff, exhaust diff, radiator diff, accessory mounting diff etc
Old Feb 27, 2005 | 08:10 PM
77300i6's Avatar
77300i6
There was another thread on this forum about a week ago
entitled "Why Would Anyone put a 300 in an F-250" .
I think the real question whenever swapping motors is
what will I use this thing for? I run a 300 six and at first
I wanted to rip it out ASAP. After driving it for awile I realized
that It did everthing I asked it to (except win a drag race )
The way I see it, when these trucks were bought new, They were
ordered with an engine for what the owner intende to do with it.
If your needs are similar. then dropping in a big gas guzzing V* would
be a waste of money. This isn't to say I don't like 460's. A buddy of mine has a '78 with a modified 460, let me tll you that truck will RIP! Even with a 6" lift a
35's that 15" wide. The down side is the 10mpg with a light foot.
Back to your original question, what for a transmission do you have? If
you have a M/t then you can just swap the bell housing, if it's an auto then you need the whole thing. A C6 from a 351M/400/429/460 will work.
For headers a lot of people go with the L&L fenderwell exits, which will rust/
corrode dispite their claims. Go with the powersteering pump from the 76--77
models(not the saginaw used on the 78-up). My buddy ran into this
problem when he swapped in his 460. Most importanly pay attention to the details. It's always the little things that bite you in the ***.
Old Feb 27, 2005 | 08:21 PM
yaki69's Avatar
yaki69
alrighty i have a c6 froma 302 outta a van both engine and tranny for 200 bucks..i havent really dug into it and seen if its all good to go but from the looks of it , it looks fine. but, what aftermarket m/t would bolt up to a 460? would a tremec heavy duty 5 spd work? im mostly gonna use it to drag race around, and just plain ole hot rodding.
Old Feb 27, 2005 | 08:54 PM
zwinstead's Avatar
zwinstead
that C-6 from a 302 is useless for your 460. A toploader 4 speed would be the easiest swap for street racing. I'm sure you could adapt a Tremec, however I dont know how well it would handle the trucks weight behind the monster 460 torque. Most Tremecs I know of were designed for use in lighter vehicles i.e. mustangs etc
Old Feb 28, 2005 | 07:51 AM
77300i6's Avatar
77300i6
Well, now I know more about your application I would say how much
money can you afford. As zwinstead said a top loader may work. Or,
if you have the $, you may want a Richmond 5 spd, Thats if you want
a M/T. You may be better of with a C6 with HD clutches, manual valve
body and a 2500 rpm stall torque converter(depending on gearing, cam,
powerband, ect.) For street roding I wouldn't go steep on the gears. That
460 should provide adequate torque to get you moving. I would go with
3.50-3.73:1 gearing.
