Sponsored by: Real Truck
Anyone know
Old Feb 27, 2005 | 12:39 PM
Fordinator's Avatar
Fordinator
Anyone know
Where to find Fords TSB's,,
Old Feb 27, 2005 | 02:47 PM
high ho silver's Avatar
high ho silver
Smile
Go to the top right corner of this page and select RECALLS/TSB'S. You should be able to manuver around from there to find what you are looking for.
Old Feb 27, 2005 | 02:53 PM
captchas's Avatar
captchas
Guest
http://www.infotraxx.com/index.php
you can also try here
Old Feb 28, 2005 | 07:13 AM
t_j82's Avatar
t_j82
You can go to: intellidog.com/dieselmann/60bulletin.htm it is updated about every 2 weeks.
Old Feb 28, 2005 | 04:03 PM
Fordinator's Avatar
Fordinator
I tried the link up top,,no luck,,but I'll try the others,,thanks
Old Feb 28, 2005 | 04:50 PM
high ho silver
I had a hard time figuring out how to use the link up top too at first. When you select the link above you will be asked to supply vehicle info. then when you submit you will probably get an error page. Don't stop there because you can select from the toolbar underneath the header "nhtsa" . Select from complaints, defects, invest. recalls, and service bulletins. Try that!
