91 F-150 320 Engine Knock
Old Feb 26, 2005 | 11:19 PM
carpking43's Avatar
carpking43
I have a 91 F-150 with 123000 miles on a 302 motor. I just purchased this truck fairly reasonable but it has a pretty bad knock at startup which gets better after a few minutes, but still knocks. Its not a little tick, its more like a clunking! The oil pressure gauge is towards the low side but does not fluctuate. Any suggestions on what this might be? Should I look for a replacement engine or fix this one? Is it reasonable to think I can repair for under $1000.00?
Old Feb 27, 2005 | 01:12 AM
mako5972's Avatar
mako5972
It sound like the bearings are bad and that the crank shaft may need to be ground.
Old Feb 27, 2005 | 01:52 AM
pfogle's Avatar
pfogle
You could just get a crank set, how is the oil pressure when it's warmed up?
Old Feb 27, 2005 | 04:20 AM
carpking43's Avatar
carpking43
The oil pressure gauge never changes from startup or when warmed.
Old Feb 27, 2005 | 05:45 PM
mako5972's Avatar
mako5972
Get a known good mechanical oil pressure guage and check the oil pressure first. If it still registers the same way, check the bearings using plastiguage.
Old Mar 1, 2005 | 08:18 PM
95 F150's Avatar
95 F150
Just drive it until it drops and just replace it with a crate engine
Old Mar 1, 2005 | 08:34 PM
carpking43's Avatar
carpking43
Going into shop tomorrow - advised by my mechanic that I shouldnt drive it 600 miles pulling a boat, go figure! I still have no clue what it is, truck runs fine but knocks terribly on cold startup and when under load!
Old Mar 2, 2005 | 09:35 AM
carpking43's Avatar
carpking43
Well, mechanic called today, I lost what he was saying after wrist pin and big bucks! So the secondary question now is - will any 5.0 302 fit even if from a mustang? I guess I will go with a used engine vs rebuild since I dont have a ton of money to spend!
Old Mar 2, 2005 | 01:24 PM
95 F150's Avatar
95 F150
The mustang engine has a different camshaft oriented more for top end power where the truck engine cam is designed to make low end torque and midrange power. If you use a mustang block you will end up reusing alot of things from your trucks engine.
Old Mar 2, 2005 | 04:00 PM
carpking43's Avatar
carpking43
Found a 302 from a 1989 bronco!
