Overheated Tranny
Old Sep 27, 2001 | 08:04 PM
canadianfordman's Avatar
canadianfordman
Overheated Tranny
Old Sep 30, 2001 | 06:31 PM
jdcoffi's Avatar
jdcoffi
Overheated Tranny
It was a hot day and I was hauling about 1000 lbs of slate across down (stop and go) in my 1981 F-150, FWD, with auto trans. My truck started to shake like one of it's wheels was coming off, then it felt like someone was applying the parking brake. As soon as a I realized what was going on (maybe 20 or 30 seconds) I put my truck in neutral and pulled off the road to let it cool down. Once cooled down my truck seems to run OK but I have not pushed it to the same degree. Does anyone have any suggestions or explanations? Does this episode warrant any special maintenance? Thanks.
Old Sep 30, 2001 | 06:49 PM
85351ho's Avatar
85351ho
Overheated Tranny
change your filter and fluid since its probably burned, and install a tranny cooler
1985 F-150/351Ho/c6/4wd~96,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt 4.10 gears, 250 springs
37 boggers
Old Sep 30, 2001 | 07:29 PM
Franklin2's Avatar
Franklin2
Overheated Tranny
Yes, see if the fluid on the dipstick is brown and stinks. It should be light pink/red.
