Here is a stupid one for ya'll. Those gaskets that come with each oil filter element...is it really necessary to change that every single time? I've been doing it every other time and it seems fine.
nope...just a pain to pry the old one off and put a new one on for no reason. So I don't. I inspect it..make sure it's not damaged...and then it goes right back on.
I'm no ford diesel mechanic but I have been a marine diesel mechanic since 1976, mostly cat and detroit engines, some japanese makes. You cannot believe the problems I have traced due to gasget and poor filter replacement on diesel engines. Looks like the ford filters are under pressure, not under suction, so a bad gasget would drip fuel, but, my advice would be to be VERY carefull when replacing filters. Use new gasgets, do not let debris trapped on the filter drop into the conditioning module on the engine. Suck out all the junk out of the engine module! I have not changed my filters yet because the engine has 11K on it but you can be shure I will be very carefull, especially with the engine mounted filter.
On the boats I sometimes pull the filters apart to see what is in the tank, it tells me what the fuel supplier has been selling and what problems to expect down the road. Its kinda messy but information is a good thing. Do not expose your self to too much fuel, wear gloves, wash you hands. I'm always amazed at the younger guys who bathe in oil and fuel. This stuff causes cancer, I'm luck to have survived it.
These are not gaskets, they are Buna O-rings. And buna, over time gets hard and conforms to the shape of the hole it's in. You can not do a proper inspection with it on the cap so if you have it off anyway just replace it. Just because there is no visiable damage doesn't mean an O-ring is good.
P.S. My background is in hydraulic cylinders we use thousands of o-rings per year and I know that a $.05 part can give you a lot of grieve.
What is involved that is painful to replace the O-ring? Do you stab yourself with a screwdriver in the process?
It takes all of 15 seconds to take off the old one, wipe the cap and reinstall the new O-ring.
You have a 12,000 engine and you are going to quibble about an O-ring????
